Hello all,
For some reason, I’m not a fan of power strip/blocks especially the ones that cost megamoney, even if they can be excellent.
I wonder if connecting 4 Naim boxes (ND5XS2, 282, 250, NAPSC) to a dedicated mains line via a Graham’s Hydra 4:1 is a good idea or not.
I’ve read through past threads here and the Graham’s product seems to have found some measure of favor. Wondering if that would still be true in my specific context. Thanks.
I’ve got the same set. up as you, but with a CDX. Graham’s recommend the power amp is plugged directly into a socket and does not form part of the hydra
I’ve had a Hydra on my system for many years, and it’s great (and relatively inexpensive, given the prices of alternative leads, mains blocks, etc).
Please note that you’re advised to have only as many ‘heads’ as you need (that is, don’t have unused ‘heads’) and that the Hydra should only be used to power Naim units (something to do with Naim’s ‘star earthing’ - whatever that may be).
The Hydra is made and sold by Grahams (Canonbury Yard in Islington), who used to be my dealers when I lived in London.
You may find the 250 power amp sounds better into the mains. So you could have the ND5XS2, 282, HiCap and NAPSC on a 4 way hydra.
I would get two unswitched sockets for your dedicated mains. And then look at a 4 way hydra that you could then experiment with.
I have 2 unswitched sockets on a dedicated radial circuit. 2 x 135s plugged directly into the mains, Lingo 1 plugged into mains and a power strip plugged into the mains. Then I have Supercap 2, 555PS and phonostage plugged into the power strip.
@Dan_M Yes, I failed to mention the HCDR which indeed is the PS for the 282. I suppose my worry was to power everything from just one wall socket, albeit a dedicated mains for this purpose. This means I wouldn’t plus the amplifier or anything else from another wall socket…Thanks.
I was never advised by Grahams to plug the power amp into a mains socket, rather than use a Hydra. It would make the whole idea of using the Hydra redundant.
That is exactly what I had until recently and it was excellent. I believe the standard length from Grahams is 2m from mains plug to the ‘splitter’ (for want of a better description) and then 1m ‘tails’, but they will make pretty much any length you need.
I use a mix of 4-head Hydra plus two Powerlines. Hydra for the lower current draw stuff such as 555P’s. Powerlines for the 300DR PS and the Supercap for 252. The Radikal is also kept as separate as possible on a Powerline Lite. The Hydra is also fully populated feeding its black boxes.
Try a Custom Hi-Fi Cables PowerBlack power block. Not in the silly money category and much better in my experience than a Hydra and indeed many megabuck blocks. Hand made in the UK by Sean Jacobs who also designs the PSUs for Innuos.
