I have a first generation Muso and want to connect my turntable to it. Is this possible? Do I need a phone pre amp? If so I could get a turntable with built in phono stage. Looking forward to your thoughts. Thank you.
Welcome to the forum. As you say, you’ll need a Phono preamp so it would be worth buying a turntable with one built in to keep things simple. Something like the Rega Planar 1 Plus or Project Primary E Phono will do the job nicely. All you need then is a 2xRCA to 3.5mm cable to plug it into the Muso.
Thank you James. Much appreciated.
