I was listening to music this morning and went out for the day. I have just come home and the light on my 250 is out. I pushed the power in and out again a couple of times. (Needless to say it isn’t playing any sound either…)
Has anyone seen that sort of thing before? I assume that something in the power supply has failed while I was away. Do they have fuses? Or is it likely to be something more dire?
Yes, there is a fuse in the unit – and assume also the plug top if in the UK. Have you also checked the breaker/fuse on your house consumer unit feed?
If it is the fuse in the unit, you simply pull out the flap next to the IEC socket and you may seen a blown fuse (care glass may be broken). There should be a spare fuse in there, which simply clicks in – suggest get new one from dealer i.d.c. (if this is the issue).
There is a better way to hook the fuse up – doubtless await others here to inform.
There are two fuses, one in the mains lead and the other in the back of the 250 in a pull-out carrier. In the carrier there is a live fuse and a spare.
