That’s how I would see it too, but I don’t have my copy of BubbleUPnP to play around anymore
Ah thanks, I did wonder how OpenHome compatibility works. It certainly explains why there’s no change in sound.
Roger
Please… I would like a Naim App that gives me a working widget in iOS 18
i’d really like that WITH ANDROID pressing one button can launch the playing of all my Qobuz’s favorite tracks (as it’s with IOS)
I’d like the App to be consistent across the devices and controllers.
I’ll try to explain. If I select the NDX2 it offers servers whereas on the Qb it offers UNPIP. Then it won’t let you select an album on your server/UNPIP as a favourite. Then on the iPad the playlists are in the order of the most recent regardless of whether list was compiled on UNPIP or Tidal, while for some reason on the iPhone it only lists the lists compiled on Tidal.
The change from UPnP to Servers was made when the 2nd gen streamers arrived. If you don’t like it, you can rename the input. Call it anything you like.
Playlists can be filtered to include whichever you want from UPnP, Qobuz or Tidal. You can choose the order between alphabetical or date added.
What I would like is a search function. i.e. I enter a name/song title etc and it just finds it for me, rather than me having to scrabble through lists of similar things.
I would like my Qobuz albums to remain in alphabetical order by artist, rather than having to reset that option each time.
I would like a Naim app that is the Naim app.
Oh - still got it.
But should I update it to the new F&N version avec Modells?
Whenever possible I listen to music in the dark.
The only light sources being the illuminated Naim logos.
I always listen with the Turn Off Display During Playback enabled and if I alter the volume, the display shows a low-intensity numeric indication of the volume - that’s fine.
But then it displays the album art for a few seconds in all its brilliance, and thanks to the high-quality display the entire room is lit up for a few seconds.
Why??
It does tend to spoil my experience somewhat and I don’t see the point.
Generally I know what I’m listening to, and if I want to check what I’m listening to I can look at my phone/tablet that I use to control it.
@Stevesky
Hi Steve.
any chance to have this apparently “simple” request fixed ? (as this fonction is already available on Ios).
We should be able to launch all our favourite titles with only pressing on one button, isn’t it ?
