I would love some help. I need easy to understand instructions
yes
I’m assuming you also have the link plug back in on the CD5X ?
no i dont have that link plug,
Do you still have the Flatcap plugged into the CD5X if you don’t have the link plug ?
Thanks for posting those. The amp looks fine regarding connections, but as you don’t have a link plug for the CD5X, you’ll need the Flatcap plugged into that. The CD player will work, but you’ll get no sound.
As you have the NAT05, and it looks like you you have it tuned to a station and the stereo light is on, I’m surprised you are not getting sound from this source. From what you’ve tried so far, it’s pointing to an issue with the amp. Are you able to plug a pair of headphones into the SN3.
hello
thanks every one for their help just as an update i have conected another device, using the streaming jack plugs and got sound. so i connected cd with Jack plugs and also got sound. cannot get any sound from CD or tuner using DIN conection, anyone got any ideas ?
Ok, it’s good you are getting sound via the RCA input sockets. The DIN and RCA input sockets are paralleled on the SN3 so both should just work.
On the CD5X you are getting sound via the RCA outputs. Try the DIN output again using the DIN5 interconnect cable and check that you have got the DIN output enabled. If you still get no sound then either you have a problem with the DIN5 interconnect cable or an issue with one of the output relays on the CD5X.
You could also try swapping the DIN5 interconnect you have on the NAT05 with the one you have on the CD5X.
The Tuner… Are you connected to a decent serial with a good strong signal ? If not you may not have enough signal to unmute the tuner and IIRC, it mutes inter station hiss so you won’t hear that either.
I only use RCA.
I know it been mentioned but check you have enabled Din if that’s what you want to use from the output selection on the CDP.
Just in case you missed it.
