iFi amps
I’m considering using an iFi amp for my lounge headphones experience.
Presumably, this will connect to my nDAC with a RCO Phono-to-phono lead.
Anybody have experience with this or similar?
I use the IFI Zen Stream with its Elite power supply, works perfectly and the sound is great! it has been compared to much more expensive streamer…
On the other hand, I don’t know the rest of the range.
Looking at adding a Zen Can to my 282. Any reason why this would not work?
I’m actually in the process of doing exactly that. It takes a DIN to RCA cable properly wired for output to do it and I’m waiting on mine to be delivered. It’ll take a little while because of Brex**it (I’m in Europe) but all my research showed that it should work perfectly well. Go ahead, or wait until I can report back as to whether I’m basking in headphone delight or eyebrow singed from my system blowing up, if you like.
