Hi,
I’m curious to know if anyone tried feeding digital audio from the new Ifi Audio Zen Stream into a Naim DAC-V1?
If so, what are your impressions? Does it work well? Which of the digital connections works best (USB, coax or optical)?
I’m somewhat tired of using my Mac Mini to do the job, and after the BitPerfect app is no longer supported, I keep experiencing different “bumps” in the road using this solution. Solutions like Audirvana and Roon are expensive ones I think ad wonder if my money would be better spent on a streamer like the Ifi Audio Zen Stream.
If you have other suggestions, I would be interested in those as well.
