Imbalanced audio channels
For my Unity Atom, the right hand channel is always quieter than the left to the point that if I disconnect the right hand channel it is almost impossible to hear the left and it sounds muffled. This changes from right to left if i change the speaker cables round the other way so it is the channel rather than the speakers. when both are connected as long as I sit closer to the quieter speaker then the overall sound is fine. Is this to be expected?
No I would not expect that have you checked the balance setting in the app?
