I just wanted to share with the community how I improved my Muso 1. Recently I moved to Qobuz but Muso 1 cannot handle Qobuz connect. Since I did not want to connect through Bluetooth and lose high quality sound, I bought a Wiim pro for 199 euros and connect it through the optic input to the Muso 1. I was thrilled by the result. It’s not only that Qobuz HighRes is available but also the old streaming unit of the Muso is not used anymore and replaced by the one of the Wiim which is up to date and can provide directly high quality music to the Muso. I was planning to replace my Muso 1 which is more than 10 year old but I think that I am good for another 10 years.
Sounds interesting. How is the sound quality vs native Muso? Does the Muso time out on the digital input or is it always available?
Compared to what I got before, I found the sound greatly improved after this change. I believe that this is coming mainly from the streaming unit (wiim vs muso). After a while of no use, the optic input is disconnected but just need to open focal / naim apps and it starts immediately. Not a big deal.
This does seem very interesting. A couple of questions
So the poor wireless capability of the Muso1 is replaced by the Wiim pro. Is this correct?
Which app is used to control the music? Wiim or the Naim app?
- Yes
- I control the music through the Qobuz app because the wiim pro can support Qobuz connect (and not the wiim mini if I am not mistaken). Same can be done with through Spotify or Tiidal. The music can be controlled with the Wiim apps as well.
- The only (very) small issue is that the Muso disconnects the optic input after a while if not used. Then when I launch the music on the Qobuz app and have selected Wiim pro, if I have no sound I have to launch the Focal/Naim apps and select the Muso. It takes 5 seconds, not a big deal.
Yeah, given compute/software platforms age comparatively fast, I usually looks for systems with “as standard as possible inputs”, so you can plug another “streamer” in front of it. (Like analogue/chinch or SPDIF/digital input, if there is a decent DAC included.)
Plain old Erhernet also has great backwards compatibility across decades of product generations.
