Let me be your french teacher and english teacher too:
Joie de vivre
Sound
Added
= 3 faults.
. I know, the phone keyboard is a disaster.
Joie de vivre
Sound
Added
= 3 faults.
Good enough is not good enough for these ears.
My 2.2 gives my mid spec LP12 a real challenge, it is just so engaging in original form. Yes it has a Hiline and Powerline and the 282/SuperCap suits it particularly well, so no need for XPSDR…yet…. It is the first and only CD player I have enjoyed and I am eternally grateful to Alastair at Signals for foisting it upon me for a non-refusable price!
Cdx2.2 into Nait 50 here as well. I took the opportunity to trade in my first CDX2 for the 2.2 to get a late model and hopefully extend its life.
Brilliant player and the physical operation of them just enhances the appeal over most other CD players.
Yes still own my CDX2, an early model I bought from new. I don’t currently use it… I have bought a separate CDT now… my CDX2 has no digital output. I had thought of getting it converted by Naim, but it’s a destructive one way process and I thought I’d leave it as it is, and instead get a separate transport, which I use a fair bit.
I still believe if one cares about the machine too much it kills the music.
I do recommend source the donor parts and skilful technicians in advance, just in case it dies suddenly.
have a recap and so forth it sounds fresh like the first day, and feel thankful to all the great designers at Naim.
My CDX2.2 / 2004 year (by serial number), with updated mech / board by naim at the factory → around 2014(?). It has provided many years of musical enjoyment here and with the move to NC pre + power, the player has continued to expand its remarkable capabilities.
I really miss my CDX2. It is the one piece of audio equipment i wish i still had. It just has this inherent drive and boogie that i have never heard replicated by another disc spinner.
I am looking for a transport to add to my current setup, but fear it will never quite meet my expectations.
Linguistics is not my strong point FR…I will be guided by yu, merci.
I intended good enough as faint praise!
Gods demand full-blooded, totally committed, and utterly dedicated praise. Faint-hearted never won gods’ grace!
Thats the difficult part.
Per, I know you bang the drum a lot about serviceability, but the Philips platform is perhaps the most widely understood platform. There are so many engineers around that you’ll most certainly will be able to find someone to fix a cd player.
Still have mine packed away…not sure what to do with it yet. Sad that it’s no longer supported by Naim re the mech. I used to have it hooked up via an xpsdr which I now use with my ndx2
Still have it, had it changed to a CDX2.2 - just before COVID hit. Like you I have a Nait 50 , very pleased .
If it expires during my proposed move ( it is nearly 25 years old) I will probably replace it with a Pro-Ject CD transport
Give it to the Valkyries!
I seem to recall when we had Naim CD players many years ago that Naim advised against the use of any lens cleaning disc, or trying to clean the lens in any way at all. I can’t recall why exactly, but I know we never touched ours in any Naim player we had over the years. I would never use a lens cleaning disc in our Moon CD transport for this reason.
Keeping the lens clear and dust / dirt free is very important as with any optical device. The advice given was possibly to protect against consumers using products that might damage/scrach the lens or damage the mechanism through in appropriate cleaning - and defer the consumer to using a professional service or equivalent to clean after an extended time.
I would also guard against blowing on it with your mouth - as you will cover the lens with fine drops of saliva. There are low velocity and filtered puffers available that can work well and are used elsewhere for very delicate optics and sensors (ie ultrasonic transducer mounted sensors) as used in high quality digital cameras
Thanks Simon. The puffer option isn’t viable with our Moon CD transport as the lens isn’t visible/accessible. I agree blowing on it (if it was accessible) will result in saliva deposition, even if not visibly apparent. I can’t recall the exact advice from Naim, it was so long ago now, but that’s why I’ve never used any kind of cleaning CD. Are there any particular ones you’ve tried and think are good? It seems to me that any kind of cleaning fluid is a bad idea as IME all such things tend to leave chemical deposits.
I don’t use a CD cleaning kit so can’t recommend one. I have used a filtered photographic puffer very occasionally on my CDP/Ts which do have an accessible lens. Though I always avoid touching the lens - as you will add to it with dirt and if from yourself, skin oil. I discovered this with hi resolution photographic sensors. CD lenses are quite a bit more robust and tolerant than hi res camera sensors,
I tend to leave a CD in the player when not using it to shield the lens, although it can weaken pucks over time - but is manageable
