It has been a long time since I used this cable - IIRC we had one at the factory for evaluation back when it was introduced. A cable that was difficult to forget thanks to its unusual dual cable run construction. Best ask The Chord Company what they think.
Thank you all for your replies.
I have contacted chord and was told that yes they are known to have slight movement in the center pin and so long as there are no issues, its nothing to be concerned about.
I should have known about certain normal “wobbly bits” being a naim owner
Ok that’s interesting.
Seems like you have had quite an expensive experience with a plug replacement from chord.
Can you elaborate?
Have always thought the expense would be more the cabling than a plug
