Innuos help with quboz album integration
Afternoon collective!
I’ve just got an innuos Zenith mk 2 and tried several times and re booted but I can’t sync my quboz library. The playlists show up on the music/ my library page but the albums and artists remain at zero after repeated taps on the resync button, but all there on the quboz widget. Which takes me to my account home page.
I’m currently importing my local music from a usb drive and they are all showing but i thought Sense was able to integrate both local and streamed artists/ albums in one space like Roon does?
The issue was a Qobuz one with a third party. It has impacted multiple manufacturers, although the tight integration with Innuos Sense meant that Innuos users were the first to notice and report. It’s taken approximately a month to sort but has been sorted by a new OS update this week for Sense which you run by going to System - Settings - System Update.
I’m not sure this applies to Mark 2 products though. You could try asking on their forum.
And bringing myself up to speed from said forum…
“… a maintenance version of the fix will also go out for MkII devices running innuOS 2.x.“.
That should hopefully sort you out.
Ah cheers!! I’ll wait for the update then.
Much appreciated
