Excellent many thanks I drew a blank when asking Google.
A good read, impressed it improves on the SE and recall someone saying the same as the review, that the SE and Phoenix get you close to the Innuos Statement.
More interesting is the mention of the MUTEC clock. Before I went the Audiophilleo SPDIF converter router, Innous advised the Mutec USB 3 and later to add the clocker.
I do like the Phoenix can just be added to my setup, but I was hoping it would relegate the Audiophilleo, which is clear from the review it won’t.
long story I had the AP2 with PurePower ending up developing an issue, dealer tried to resolve and finally as an exceptional good will gesture swapped for the AP1 SE, I did not realise it had no Pure Power.
I’d need to return the unit the AP for the $450 upgrade to PurePower.
Thats the one, its the module to the right thats the battery, idea being when streaming power is supplied from the Pure Power and the power feed cut to further eliminate noise.
On my AP2 I purchased it with the Pure Power, was fine then something went wrong.
The AP1 is interesting as firstly it negates the need for an additional BNC cable as it plugs directly into the Nova BNC.
In addition the designer allows a virtual cable function, so you can noise shape to your hearts content, his view in this instance cables (usb) are irrelevant.
Reminds me of the USB Audio Player app that uses Morphit to match well known ear/headphone sound profiles, be neat if the same could be done with the AP1.
The Phoenix cost is bonkers though, but living with various older and my current Innuos servers, I appreciate just when you think you have squeezed max performance from a streamer, the next box up the ladder takes it even further, flinging open the window.
I’ve had the Phoenix for the last couple of weeks now and it’s as good as all the reviews and early adopters have described.
I’m using mine with KEF LS50 active speakers and a MK2 Zenith and the improvement is not subtle.
Soundstage has improved by quite some margin, instruments now seem to have their own space; the noise floor has dropped as I’m hearing things which I’ve never heard before; timing has improved (feets tapping a lot more!); The top end has a lovely shimmer to it; you can now drum cymbals trail off more realistically.
Yes it’s expensive, but having listened to it for a few weeks now, I can say it’s the best upgrade I’ve made.
No Naim in my setup (sorry!) but if you get a chance for a demo, I’d definitely recommend it!
