Working fine on my Statement and Atom HE, and sounding very nice. It was a relatively quick update.
Incidentally, select Naim Uniti as your server type even if you have an ND555, for example. They may come out with a separate option for different Naim models later.
Might be a full public release but deffo V1.0.0 using my UnitiQute II, album, track and volume selection/control iffy and slow, requiring multiple taps on IPad Pro with indeterminate results……
Reverting to Naim App UPNP for better experience.
Or perhaps not…. After 5-10 minutes performance improved markedly for album and track selection, volume control still a bit slow/hit&miss, but volume display in Innuos App now matched UnitiQute II.
So struggling to decide, discern between Qobuz 24 bit and Tidal Masters.
Dropped from 3 albums to 8 tracks, no clear winner, some Tidal is better, others Qobuz.
On one album Tidal sounded odd, i think, i cant be arsed with this over analysing.
At the moment i would say its negligible if that.
Am I the only one who has problems with my album artwork covers no longer are displayed on the Nova display after Innuos 2.1.0. update? It seems to work with Roon but not with Innuos and Tidal
Are you 100% sure they added the decoder to perform the first unfold. Release notes don’t suggest that. Do you get the sample rate showing on the Nova to verify its decoding ? Another user isn’t getting MQA to work at all to his MQA capable system via Sense via USB or UPnP.
Innuos Support confirmed to me it is the full MQA, my only indicator is the Sense app which always shows the track data, Nova is fed via the Audiophilleo so it does not display any info, it is just passed to the Nova DAC.
