Innuos Sense 26 - Classical Mode
Innuos Classical has arrived. Currently doing a rescan of my classical content. Thoughts?
Don’t listen to classical but it has my request for release year with album so I’m happy
My library is still updating after 6/7 hours. My library isn’t excessive so I’ve posed a question on their forum.
I have also made the update and have found there is a long rescan, which is ongoing.
The rescan took about 10mins on mine as I have a tiny library, 99% of playback is Qobuz or radio though.
Innuos have just told me that the length of my rescan thusfar is perfectly normal as it rescans rips for new metadata. So, I’ll let it run for the day and see where it leaves me.
The fact there’s no meaningful way to distinguish between crashed/frozen and working as it ought has been raised by a couple of us.
Glancing at a few albums where it has updated is eye opening. The use case for Roon shrinks once again.
EDIT: It appears I am done. It’s a very impressive update. Puts it well ahead if much of the oposition. Although its described as Classical Mode there is no such thing. It’s just a big rewrite of how the whole thing works. I am liking it more for non-classical albums even though what they’ve done there is huge.
Can’t get my head around why it says neither Qobuz nor Tidal have been synced since September when that’s plainly not true.
I’m very pleased with it, too. Presto integration apparently also coming soon. I’m finding Presto SQ much better than Qobuz.
I am currently running a backup of my Zen 3. It is taking much longer than usual, I think this is due to the updated metadata created by rescanning the music library after the install of Sense 26. However, it is probably worthwhile as the library rescan took so long that I don’t want to have to repeat it.
I do my backups at the end of the month so will report back then. Otherwise think it’s an excellent update so far.
A bit overdue with my backup having been away but have started it now and initial signs are that it’s certainly going to be a longer one than usual. How long? We shall see.
41 minutes for the 1st backup. Not too bad. Presume next momths will revert to 5? Second backup backup now underway.
