Does anyone know if both audio outputs (ethernet and USB) on Innuos Statement can be connected simultaneously? i.e. can I connect a Naim streamer (ND555) via ethernet and my Violectric headphone amp (with DAC) via USB at the same time? I am curious to try the difference between Statement/Violectric vs Statement/ND/552/Violectric.
Yes as both network and usb are independant.
Thank you!
Supporting this in a way is the fact that you can for example get the Statement to play to ND555 and Atom HE simultaneously although both are connected using Ethernet
