This might be a stupid question but here goes. I have hooked up my ND5XS with my Supernait and can control volume on the SN. But is there a way to use the ND5XS remote to also change the input on my SN?
Yes, you need to set up System Automation.
I have my NDX linked to Supernait(1)
Go for the manual instructions from ChrisSU’s post & see how you get on, but if you get stuck come back & I have it written up in one line idiot board format (I used to reset to factory defaults a lot for beta testing)
I managed to solve it Thanks!
