Input trim missing for digital input in Naim app?
This used to be useful for balancing optical against native TV for, it was there, then went, then came back and has now gone.
It’s still there on the HDMI input, can we have it back on the digital input please or was there some mission-critical reason it was removed.
On that note, why do companies just remove stuff like this these days?
‘You won’t own anything and you’ll be happy’
Might be easier to answer your question if we knew to what Naim equipment you are referring.
Naim Muso2.
Naim are aware that it has disappeared and it will be fixed.
…and I also notice that the digital input ‘lip synch’ has gone. Terrible vocal echo ensues!
Can we have that back as well
DBS.
