I’m considering the purchase of a Lyngdorf MP-50 theatre processor. I also use my theatre for 2 channel listening via theatre bypass on the N272. The Lyngdorf only has balanced output.
@Richard.Dane Is there a preferred way to integrate from a theatre processor to N272 from a sound quality standpoint? I believe you can use either DIN input or unbalanced RCA for theatre bypass. Is that correct?
If no concerns going from balanced to Naim DIN does Naim make such a cable or should I reach out to my dealer to source a custom cable?
Scott, yes you can use either of the analogue inputs on either RCA or DIN. You just need to set that input to AV bypass - that way the processor will take over volume control for that input.
You’ll need a custom cable for going balanced to single ended - talk to your dealer.
I can’t think of any - except that for best sound I generally prefer DIN to RCA Phono. As for hum, I have no idea - it’s something you’ll only know about when you try and may also depend on the i/c as well.
