Interconnect Advice
Okay, Skeptikal
I hear what you’re saying. My understanding is also that the original interconnect cables are quite good, and I’m not dissatisfied with them either.
However, I have an interconnect from my CDX2, DIN to RCA on my 272. This is made by another company that specialises in making cables for Naim boxes (I won’t mention the name because it’s against the rules).
This interconnect sounds excellent.
I hear you Mike, Thanks :slight_smile:
@Peter63
There is another company that makes my Mogami cables I’d run past to keep the cables the same.
But I can’t post a link.
But his name is Yannis Tomé :wink:
The Rothwell The River share a trait with the Mogami 2549, which is lower than average capacitance.
That looks like a good option. Thanks.
I use a Transparant Super interconnect from my 272 to 250dr. I liked it better than the Chord equivalent. The latter sounded brighter in my setup, a little harsh. The Transparant was more robust in the low, more precise and transparant.
Moving to Vertere Redline cables was the biggest single upgrade I have ever made in a hifi system. Each one was an instant difference. Not just different, but better in all the ways that people describe hi fi improvements. A bigger difference than adding an NPX300 PS, if that helps to pitch value for money.
Hi Ron. What kind of cable is it, who made them?
Mistyped… it’s Transparent SUPER RCA Interconnects
I auditioned Clearway, Shawline and Epic rca at the same occasion.
Shawline and Epic were very close to my ear, but Clearway sounded thin in comparison.
Transparant Super interconnect balanced, made for Naim. Manufacturer is Transparant Audio in Saco, USA.
TransparEnt !
I’m in full agreement with you @BrendanD. Redline is a major upgrade in both power cables and interconnects. The OP has already said that Epic X “Still a bit pricey though”.
That statement puts Redline way out of the OP’s budget.
Presumably you mean unbalanced if you’re using it with a 272/250.
Hi Chris. If I use it with my 300 then its balanced? Im not shure what it means with balanced. Is it the connection or the cable in it self? Im confused
If you mean a NAP300 it’s unbalanced, like your 250, despite the fact that these amps use XLR plugs more commonly found in balanced connections.
If you mean 300 series (New Classic) these do use balanced connections with XLR on both ends, and these are not ‘Naim specific’ cables.
Let’s say I bought them “balanced”. It’s what’s said in the specs. Manufactured for this Naim solution only. It uses one analoge 4pins DIN of the 272 to the XLR of the 250dr. Only some manufacturers sell these interconnects apart from Naim I’ve been told.
Anyway, I am happy with it.
Yes I mean NAP300 DR, thank you for a good answer
OK, so they are unbalanced DIN to XLR, like the Naim supplied cables.
Would the Mogami 2549 also be suitable as a turntable cable, due to its capacity?
