Interconnect between WiiM Ultra and NAC 82
Hi all! I bought a WiiM ultra and thought the generic rca to 5 pins din cable i own could work but it does not.
So i’m asking to WiiM owners which interconnect to the preamp they use and which is the best input in their experience.
Thanks a lot!
Any 2x rca/phono to 5 pin din (180 degrees) should work.
Either the cable is faulty, or it’s an output cable 5 pin din “rec” to 2x rca eg for a tape deck.
How did you use the cable previously?
Hi Robert! Probably it was on a tape deck but i can’t remember.
I’m scrolling catalogues for a suitable one.
Thanks a lot!
