Hi there,
Have had a uniti atom for 18 months or so now and its been really good so far, however since the last firmware update 3.3.0.4300 I’ve had some issues. The unit will not respond to the remote or the app, and it will sometimes display error code 238. If I remove the power and reboot it it will be fine for 2/3 times then the same thing will happen again. I have done two factory resets (holding input and play/pause button down for five seconds). Has anybody else seen this? I suspect its linked to the latest firmware release, just wanted to check anyone had a fix for this before I go back to them?
