As above. Does anyone know the differences in components or construction between these two?
Replying to myself I have found this from our own RD on the Olive vs 250-2
“Basically the arrival of the “new” NAP250 in 2002 saw a complete change in just about every area; A new look - the current triptych casework; a much bigger transformer - now 1020VA; completely revised internal layout with lifted resistors, stable hemispheres for close temp matching of componentry, and Naim’s custom 007 transistors throughout for both regulation and power stages.”
Yup, was about to post the same, but glad you found it.
Note that the extruded case CB NAP250 went through a few notable changes. First, in 1982 the BDY58 transistors were changed to Naim’s own custom-made NA001s. Then in 1984 the 400VA transformer was uprated in line with then-new NAP135 to 500VA.
So… if… I owned a Dec 1985 build CB 250, I would have Naim NA001 power & regulation transistors and the (Holden & Fisher) 500VA transformer… ?
Yes, exactly.
Yes, but apart from that …!
It’s an Olive , apart from that it answered my question, being post CB and different to the 250-2. Richard has now added to my knowledge with his CB changes.
Those transformer changes are significant over the years. With the 250.2 at over 1000va !
Indeed, hum tastic.
There is that. But a huge transformer given the output. But I suppose it is over 2 channels.
The degree of change between the Olive 250 and the Black 250.2, is so large that perhaps using the ‘250’ name was misleading. Its effectively a different beast altogether, albeit of the approximately same configuration - 2 channels & regulated.
They sound entirely different
How did you find the difference - better in which area?
Sounds like calling it 260 or anything other than 250 would have been helpful here.
The ‘classic’ CB/Olive 250 was always listed as a 70 watts per channel, into 8 ohms, amplifier. The ‘250’ came from 2 x 125 watts per channel into 4 ohms.
The 250.2 was listed as 85 watts per channel (*). I thinks that is pretty clear.
I can only guess that the ‘heritage’ said it was still a ‘250’…?
The 300 is listed as 90 watts per channel.
(* - Something odd… the present 250 version is listed as 80 watts per channel…?)
Ok, a bit more info, extracted from my collection of Naim Price Lists over the years…
Up until 2002, the 250 was listed as 70 wpc.
In 2005, I find it listed as 85 wpc, up to 2011.
In 2013 it is listed as 80 wpc.
So… is it - BD/CB/Olive 70 wpc, 250.2 85 wpc, 250DR 80 wpc…?
If so, why did the power drop with DR…???
To make the Nap300dr look better?
