Hi everybody, since 24h internet radio station are not playing (all stations) on Uniti and on all my Qb’s. They are “connecting…” but nothing happens. A reset did not solve it. Can someone help?
Thank you. Joël.
All OK in UK, I expect it’s your local server that’s down.
Where are you?
Hi Mike, I’m in Belgium. But Naim Radio or Radio Paradise are not working neither.
Tidal is working fine on my Naim devices.
Bonsoir Joel1
OK, I still think it’s most likely the local vTuner server that’s off line.
Tidal is a separate system & server.
OK Mike, thanks. I’m not very familiar with a vTuner. Who needs to do what to make my vTuner server run again? Still no internet radio (2 days now).
Hi again Joel1, vTuner is the web radio service that Naim use.
Thanks Clare, all will be sorted with Stevesky on the case
Hi @Joel1
I’ve checked the uptime stats and the priamry VTuner server has been responding fine. See:
We run 2 servers (primary, backup) so even if primary is down the products temporarily switch to backup.
a few diagnostics tests:
See if you can browse to: Naim.VTuner.com
This should show a webpage allowing users to add stations that are not in the database. It’s hosted on the same server. -
Go to your computers command shell (cmd on PC, Terminal on Mac). Do a tracert naim.vtuner.com. It should resolve to 192.227.85.88 It may show that a network link is down between your ISP and the final server used for VTuner. Here is mine from where it leaves London and hops over to USA:
9 17 ms 15 ms 35 ms be2868.ccr41.lon13.atlas.cogentco.com [154.54.57.153]
10 95 ms 96 ms 99 ms be12497.ccr41.par01.atlas.cogentco.com [154.54.56.130]
11 107 ms 106 ms 96 ms be3627.ccr41.jfk02.atlas.cogentco.com [66.28.4.197]
12 94 ms 131 ms 103 ms be2806.ccr41.dca01.atlas.cogentco.com [154.54.40.106]
13 117 ms 110 ms 185 ms be2112.ccr41.atl01.atlas.cogentco.com [154.54.7.158]
14 122 ms 127 ms 128 ms be3482.ccr21.mia01.atlas.cogentco.com [154.54.24.146]
15 125 ms 132 ms 132 ms be3454.rcr51.bct01.atlas.cogentco.com [154.54.85.114]
16 123 ms 134 ms 123 ms te0-0-2-0.nr11.b036278-0.bct01.atlas.cogentco.com [154.24.7.210]
17 136 ms 129 ms 131 ms 38.104.222.130
18 * * * Request timed out.
19 * * * Request timed out.
20 132 ms 129 ms 123 ms 192.227.85.88.hosted.at.cloudsouth.com [192.227.85.88]
If that doesn’t help please raise a ticket with our helpdesk who can run a network scan with your assistance and hopefully will focus the issue in.
Best regards
Steve Harris
Software Director
Naim Audio Ltd.
Hi Steve, thanks for your quick answer. It now works again on all my devices!! I didn’t do anything.
Not sure if the vTuner was dead but for sure it is now alive (Schrödinger’s cat?).
Thank you! Joël.
