Internet Radio Issues
If you go to the Internet Radio tab on the app, it should take you to a page of options. Select the International tab, and then you can choose the region of the radio station you want. You might have to go through pages of tabs to get to the radio station you are looking for.
This post from @Stevesky explain the territory biasing;
I now see the ‘International’ tab - which allows selection to all regions, countries etc.
Most stations stream at higher rates than the same with vTuner before and buffering time has reduced 10-fold!
Thank you all for assisting and especially Naim for providing a swift, elegant solution once again.
Dear Richard,
Like other visitors of this forum already stated, good work in updating the app and their users.
I have two remarks, though. For Dutch broadcasts, some are now available in HD. Great! But why are these broadcast about 1 to 1,5 hour later than the real time streams?
After the update to 4.9 I can not control the volume of my ND5XS anymore. Do you have a suggestion for me (us) to fix this?
Thx for you’re reaction.
On the feedback and requests thread, @Stevesky posted about Time-shifted HD streams that aren’t supported by the early hardware;
Re. the volume, I don’t know, so probably best to contact Naim support.
Check! I will do that.
I need to.replace the neon display nac 172 so havent downloaded the update. I am.assuming that this might completly silence my streamer preamp.
Is it possible to reset without display as i use phone app, or just leave it well alone.
Your response is highly valued Richard.
On the NAC-N172 I don’t know for sure, but I know a man who probably does… @NeilS
You will be able to update the 172 without a working screen, the factory reset at the end of the update process isn’t strictly necessary, so just delete and re-save any iRadio presets afterwards.
There is a method for carrying out the factory reset from the front panel - if you wish to do it, let me know & I’ll refresh my memory!
Bear in mind that a factory reset will lose any wifi credentials & those won’t be easy to input without a working screen.
Neil.
Hi, it’s few days that in the morning my NDS looses radio connection for few secs. after a while it reconnects. apparently this does not happen reading files from the NAS, so is not a modem issue. is cable wired to the network. I updated NDS with new firmware and has worked perfectly for some time. anything happening?
