As I mentioned in another post, I am new to the Muso Qb - just bought it yesterday. There were a few problems which I managed to solve with some help from this forum.
I’ve come across another problem. The internet radio facility has 5 stations by default and that’s it!!!
When I select the Internet Radio icon on the App on my iPhone, it takes me to a screen with nothing on it. I am attaching a screen shot.
It’s totally blank except for a search facility. There are no other stations. The search does nothing. A friend of mine who also owns the Qb tells me there should be a list of thousands of stations.
I’m in Melbourne, Australia. My friend is in another country. What is the problem?
My Qb shows a similar (UK version) of what @KVC has posted. It might be worth uninstalling and re-installing the app as @elverdiblanco suggests. If that doesn’t work, you could try resetting the Muso (use the resetting tool to push the pin-hole button for > 6 seconds and let it reboot) and perhaps connecting it with a wire, at least as a temporary measure to rule out wireless issues. If you still get no joy, it might be time to contact the seller and/or Naim.
I stopped the DLNA Servers I have on my network and almost immediately all internet radio stations were available. Never though DLNA can be such an issue! After that I turned on the DLNA Servers again. This time I found no problems with my network and all the features on the Muso seem to work as advertised . No reset was required, though I suppose each setup is different and some may require a reset.
I’ve been switching between internet radio and DLNA many times and so far things are stable. Hopefully, that’s cured all the problems.
