IOS 26 and Naim app
So, has anyone here been brave enough to install the brand new IOS 26 Beta for developers?
I have the option to install it. But, I would be in trouble if the Naim app was not (yet) compatible with it.
Maybe if I feel brave (or foolish) later, I will install it and report back :slight_smile:
I’ve been burned in unusual ways over the years installing their betas. I’ll wait for a bit before I install it. Some of the new features look pretty cool and useful.
I swear watching the video a “Spam” call showed up on my phone! The new filter(s) can’t come soon enough IMHO.
Well I updated to iOS 26. All is well with the Naim app. Everything else is also working well.
Here is what the Naim app thumbnail looks like with the glass look.
You are far more brave than I
I don’t know about being brave. Maybe it has more to do with impatience and FOMO :rofl:
Hi
I’m confused I’m on iOS 18.5 on IPad and is current. :thinking:
Am I missing something?
New look, new…everything. Beta version for now, general release in a few months.
Thanks Jamie
That clarifies Cheers Jim. :+1:
Yes. Starting in the fall the software will move to the full year of release as far as version numbering is concerned. This will make all the OS numbering consistent across software type. Since there will be fewer months in 2025 than 2026, the “26” number will prevail. Right now, it’s Beta, but the version number system change will continue in the fall
@Jaybar
Thanks for that I thought I’d been hibernating. :wink: :+1:
Right now the different OS types (MacOS,IOS,iPadOS etc.) could be on different version numbering. This change will make things more uniform.
Macbook and phone both updated, no issues so far :+1:
Try going to the Update software on your iPhone. I get an error message…
Sorry to hear that, no issues to report at all, although I do realise I’ve probably put the Kabosch on upgrading my iPad….:grin:
I just checked software upgrade. It is back to normal!
Are you a developer? The new software can only be accessed by those in the developer forum.
I am not a developer. But, it is possible to sign up as one. Apple doesn’t check your credentials.
Its only beta at the moment, don’t bother IMO
Martin
I’m on appleseed and have installed. Dont bother yet is all I will say, particularly if you like making phone calls lol.
It’s working, and no issues so far.
