iOS App 5.18 & Android App 2.18 Updates
iOS App 5.18; Android App 2.18
Going live from later today (2 September 2020), this small update addresses user requests around settings, plus some minor fixes and improvements.
New: Menu option to allow the Favourites button to be hidden on the home screen (Settings > Inputs > Favourites) - no impact on Favourites functionality
Fixed: Various minor bug fixes and stability improvements
As with all App updates, we’d suggest you fully close and restart the App after it has updated. To ensure all connections are fully (re)established in the new App, a reboot of your smartphone/tablet is suggested, as is logging out and back into your music services – for example TIDAL – from within the App.
