Anyone tried different power cables for the power supply of CD players? Can you hear any difference? I can hear there are significant differences when I use different power cables for hicap dr and NAPSC. But I’m not sure about the power supply of CD player…
It’s been a while, but yes - a better power cable made a difference, specifically on an XPS.
The 555ps comes with a Powerline as standard
Yes, a Powerline improved my XPS DR feeding a NDX2, though I found the full benefit is when the Powerlines are used across the full system.
Thanks! My 555ps is a secondhand one
Ok thanks! Then I will arrange one cable for the 555ps
