I read elsewhere that some advise to set up more accurately the speed of the P10. It’s possible to change on the motor controller.
How to check the connect speed. There are apps, but not sure they are so accurate.
Generally Rega tend to turn a bit faster.
…there is a light on the back of the power supply…it flashes every 8 seconds or so to confirm factory settings. I have 2 phone apps…one says thatmy P10 is slightly slow, the other says it is slightly fast.
The instructions in the manual telling you how to change speed are very confusion…in fact, they are wrong.
For my P8 it didn’t come with a tool even though you can adjust it. The reseller got one from the distributor and sent me. It’s a rather special size. At least outside UK.
The tool is made by Rega for speed tuning. It therefor fit and work It’s a unusual size and I never found it elsewhere so had to get it from Rega. Such a strange decision by them…
I did buy the Rega strobe kit just to cover all bases. This one made a small difference (as opposed to the fancy scales and bias test record, which didn’t) because the speed was very slightly off compared to what the strobe detected. So I ended up adjusting the P10 PS by one notch. (I would not have heard it but peace of mind and all that)
I believe it’s an imperial unit. The tonearm lift height adjuster also is. Yes a bit annoying for the non-UK customer, but you don’t have to use any force for the speed adjustments, and I managed with one of my metric Allen keys
I can only think they made it an odd size to stop people sticking regular metal sized Allen keys in the hole? Deliberate design decision? Maybe I’m giving them too much credit.
Or just send along this plastic tool (1.7mm) they already make that cost them like nothing since they promote speed adjustment as a feature and include instructions in the manual.
