The mech is like this. Is it normal? Can I still use it? Thanks!
Err, well… mine is worse… Hang on I will link it…
See, here:
With a bit of care, you can remove the loose plating. Then yours will look as bad as mine - but still work… Yay…
As Ian has posted still useable, just keep cleaning the loose flakes from time to time.
@NeilS did comment - which I linked to above…
But if you wanna go straight there…
Thanks Ian
Thank you so much! Then I’m relieved.
Now get out the BluTac or sticky tape - and gently remove the loose plating…
