Just as a precaution try re-torquing the main drivers on the speakers, it’s probably not that as it’s unlikely the’ve both gone at the same time but if the bolts are a bit loose it can cause buzzing dependant on programme and probably a small variation between the amps will excite things a bit differently.
Thanks Yeti.
Have done.
And is the Qute to 250 interconnect cable the same interconnect as had been 252 to Snaxo. If so, silly question - any possibility you crossed over the inputs of the 2nd 250? Because if yes and yes, then maybe the interconnect cable.
Different cable. Qute output is 2x RCA but to 3 pin DIN input on the 250.
The active set up uses a DIN to DIN from SNAXO to 250. It uses one for each amp and I tried them both ways around.
Keep trying folks. I will try the chrome 250 tomorrow. Fingers crossed.
Bruce
New type of tinnitus, swapping from ear to ear?
To begin with I just thought Lana Del Rey was too close to the mike…
I imagine you have tried just using the Qute with your speakers to exclude a cable/speaker issue just in case the soldering on your cables is failing?
Hi Bruce,
Sounds typical of the caps in the power supplies of the 250s beginning to oscillate, I will stick my neck out & say that it occuring on both amps (purchased seperately) simultaneously is pure coincidence.
It happens gradually over a long period.
Have the 250s serviced & I think you will be delighted with the results.
Neil.
Well my wife was fed up with me chuntering so I have fiddled some more and…hallelujah.
My old chrome bumper 250 from the office is distortion free in the system passive and on the main driver active. So one needs a recap, and it probably makes sense to do both. The oldest is 1990 and I bought it a fair few years ago, the other 1995. I will ask Naim if ever serviced…bit embarrassing really.
Thanks to all for suggestions. Apols to Mrs W who wanted to do something else with her evening not stepping over cables and boxEs.
Bruce
Final fiddle; one is worse than the other but both have a bit of a drop in similar ways. No wonder I was confused.
Naim confirm one not been serviced since made in 1990, the other last done 2005.
Reasonable to give them some tlc I think.
Wow Bruce can’t complain about the 1990 one , done really well, and the other has 14 years on it.
Bruce, well done for the patient process of deduction. Yes, it sounds very much like your 250s have been on borrowed time for a while. The good news though is that they will come back from a service performing as good as, and perhaps even better than when new.
30 years and needs a service. Naim should be ashamed ![]()
