Picking up on something I posted in the headphone amp/dac - hiby, shanling, ibasso, etc thread, it is interesting if MQA makes a significant audible difference in mobile type usage, being generally limited-fi rather than hi-fi, given that in a good hifi system people often struggle to hear differences between red book and hi res. (And when there are differences they tend to be subtle, ignoring when the two have been mastered differently.)
This suggests that it is the sound changes produced by the MQA process, rather than anything to do with the resolution, that gives the MQA approach appeal on lower fi gear - maybe the MQA sound (rather than anything to do with resolution) is brought out all the more by the limitations of such systems. That is purely conjecture on my part, but it may explain the appeal to record labels or low fi system manufacturers, as opposed to companies like Naim.
If MQA only had mobile and mid fi appeal, I don’t think we would see dCS, MSB, Meridian, Aurender, and Brinkmann with >20$K USA dacs and music servers that do MQA. In addition, several folks on this forum choosing the DAVE suggests to me that the reconstruction of analog signals from the digital data has provided some interesting options for Naim followers.
My point was more that the benefit of hi res will be less over less revealing systems, incl. mobile (and often barely if at all evident on much higher level systems).
My speculation regarding the changed sound and use on mobile systems was because it seemed from cited experience on the closed thread that audible differences with MQA were often quite small, which like the difference between hi res and standard, would be expected to be less obvious in environments like cars, yet it is being cited as good for mobile use on this thread. But maybe my speculation is wrong.
Going back to hifi systems, the balance of comments on the old thread suggested some found the sound of MQA to be an improvement and some the reverse, and indeed sometimes it varied by track (which is not surprising given that aside from it’s compression aspect, MQA is also used for what effectively is remastering).
rather than any sound quality ‘gain’ by a lossy reprocessing of the existing master (actually by definition it’s a loss of information from the data!).
I guess I am one of the lucky ones, because the MQA always sounds better to me and more like live music–a goal I have had for many years in this pursuit. Luckily I am not affected by the artifacts that some hear. I do a full unfold, so perhaps some of the artifacts are heard by those doing just the first unfold. However, while technically MQA is lossy in that the digital information is changed to fix the the a/d and d/a problems with Hi Res Audio, the resulting music almost always sounds better–sometimes for the 44Khz stuff its not a big improvement. However when I listen blind, I can almost always detect when its MQA and 352/384. That is where the biggest bang for the buck is for me.
1 “MQA will play back on any device to deliver higher than CD-quality.”
2 “When paired with an MQA decoder, the MQA file reveals the original master recording.”
3 “Products with a full MQA Decoder unfold the file to deliver the highest possible sound quality. At this level of playback you are hearing what the artists created in the studio”
4 “Smartphones from brands including LG and Essential can also deliver a fully decoded MQA experience.”
Problems
Claim 1:
Undecoded MQA is 13bits signal + 3 bits partially correlated noise (otherwise known as distortion).
How are these degraded data better than 15bits signal + 1bit dither (i.e. uncorelated noise)?
Claim 2:
As the MQA encoding is lossy, information from the master is lost, so this cannot be true.
Claim 3:
Interestingly these raise two possibilities:
Either all full unfold MQA DAC systems sound absolutely identical (“you are hearing what the artists created in the studio”) and there’s no point in paying any more than for the cheapest; or this is just marketing deception and there are benefits from higher quality DACs. (There are no logical possibilities other than these two!)
Claim 4:
Taking into consideration Claim 3, if that is true, you may as well use a smartphone as a HiFi DAC to playback music even on the best of all HiFi systems as nothing can do any better than an MQA smartphone.
Indeed, I have learnt that ‘full master recording’ is these days simply increasingly becoming a marketing moniker of meaning 24 bits at various sample rates which can often sound preferable to the 16 bit equivalent. … luckily one has a choice of obtaining such recordings via lossless PCM (which I think Naim’s Steve Harris refers to as ‘native’) or in MQA. To me I am glad I have the choice, as one sounds significantly superior that the other on a quality Naim system.
But to be fair to MQA when I had my old ADSL broadband supply, I could only really stream MQA if I wanted any sort of Hidef… I didn’t have enough bandwidth. Now I have a VDSL service I have plenty of bandwidth and can happily stream 192/24 PCM FLAC via Qobuz, and so has obsoleted the need for MQA.
Hi Bailyhill, there are not any systemic issues with A to D or D to A converters that MQA specifically addresses… simply MQA allows audio frequency lossy compression whilst retaining timing information.
Further the reconstruction recovery/correction filter for MQA DACs is specifically defined for MQA to compensate for the filter response errors caused as a consequence of the MQA compression process … therefore when the audio is processed for MQA compression for an MQA distribution master, there is a greater degree of determinism on how it will sound on playback through a MQA DAC. This contrasts with PCM where users can choose filters on some DACs or even choose DACs to suit their preferences, or simply choose a neutral DAC to match the PCM master as no specific manipulation of the data and reconstruction and MQA error correction filtering is required.
I probably used the term “A to D” a little loosely. As is defined in the AES Hierarchial" paper, I was referring to the phase shifts and rolloffs in response caused by the cascading of things in the analog chain like the record microphones, mic preamps, mixers, converters pre and post, which are introduced by the record chain. They of course add to the Replay Preamp, Power amp, and transducer. The article shows the cascade effect of eight of these, modeled as a 2nd order Butterworths and shows the attenuation (which means phase shift) and the effect on the impulse response, which is quite slow compared to the quoted research that suggest that temporal shifts as small as 5 microseconds are audible and should be avoided. If one compares the microphone output to the transducer output, they need to be as close to the same to reproduce that signal–which is as close as we can get to the music.
This along with the reconstruction artifacts in standard hi res audio Dacs is what MQA seeks to fix. Of course, they can not know our preamp, power amp and transducer effects, so they can only control prior to that point in the chain.
In the end, that is the theory and the only thing that matters is the sound in our rooms. I am sure that your new DAVE will make a big improvement in reconstruction area.
Hi Bailyhill, the only artefacts or errors that MQA attempts to fix that I can see are the errors introduced in the frequency response from the MQA compression process. (The patent discusses the appropriate compensation filters). Follow the blue curve below and the resultant black curve upto 20kHz.
With regular PCM one doesn’t have to deal with these errors, other than the regular sinc (x) filter response as a consequence of the sample theorem.
The AES Heirarchial…" paper devotes lots to the limitations of reconstruction of the analog signal by most of the standard techniques of the day, and shows the advantages of a B Spline reconstruction as it applies to the timing of transient details in music. Regardless of what the Patent says, and regardless of what the Heirarchial Paper says, and regardless of what the marketing information says, I doubt very much if too many people really know what the secret sauce is, unless they have an MQA Licence and have incorporated it into their equipment. I am sure MQA is pretty careful as they would not want the copy cats out there to get a free lunch.
As I recall, a patent must divulge a reproducible recipe, but not necessary all the recipes. In addition, I imagine that there may be additional patents working their way thru the process that we have not seen as yet.
Yes you can tune and optimise, but the principles are in the Patent… clearly different manufacturers can implement MQA differently within the licence constraints…
However bottom line, the MQA compression technique adjusts the frequency response at compression, and needs to be corrected at reconstruction… not a problem, but an important correction for MQA decompression if wanting reproduce the original digital encoding as closely as possible…
I don’t think there is any ‘secret sauce’… such things are more for the snake oil merchants and Coca Cola, not reputable engineering companies … I have no doubt that MQA engineering is exactly that… from an engineering perspective they are quite open on the constraints and considerations and the benefits they are delivering with their compression techniques. It’s the marketeers and sales collateral that get carried away with speculative hyperbole (in my opinion of course…)
Warner signed with MQA in 2016 and Universal in 2017. So this is nothing new.
That they haven’t done anything more visible yet is easy to understand. It is a very small market. And they dont want to be dependent on some small entity like Meridian.
Umm Meridian have a very solid resume of delivering technology to media and telecommunications providers. MLP the carrier for Dolby TrueHD. They are not thought of as “some little company” by Warner Music, I can assure you.
I had been thinking about your rejection of the suggestion in a prior post, that MQA corrects for the phase buildup caused by the beginning of the analog chain. I had a tour of Meridian and the good fortune to spend an hour and half with Bob Stuart. So I asked him. He confirmed that MQA has a goal for maintaining temporal integrity of the music from sampling and a goal for reconstruction. Depending upon the original Master at hand, in some cases analog, sometimes digital, sometimes very well documented what processing it went thru, and sometimes not, the MQA coding may take slightly different forms. So it sounds like it does address both time smearing from the a/d and the d/a process.
Yes MQA (can) retains the temporal information after the frequency elements have been compressed… and in reconstruction it (can) maintain this temporal information BUT this only relevant for MQA as it otherwise would have been lost through lossy compression.
If you are using PCM with all other things equal this issue is moot.
Smearing is somewhat different but related, and typically refers to phase distortion with respect to frequency within the audio pass band. These days most quality DACs deal with this by oversampling and have a pass band low pass filter before the phase distortion becomes prominent… also traditionally using FIR filters tend to be better behaved with respect to phase distortion than IIR filters.
ATB
Resampling may be a great option for things that have an anolog Master. Higher sample rate is always better. That does reduce the time smearing, but it sounds like unless the resample uses something beyond the classic sampling and reconstruction techniques, it only partially addresses the problem. I would love to read about what Chord does there.
For material where the Master is in digital form, this means that some interpolation is being done and someone or some algorithm more exactly is choosing how the interpolation is being done and that’s not to an absolute standard, but to someone’s liking or choice. I would love to see Chord tell us how they do that and why theirs is the best. Talk about secret sauce–thats one if I ever hear one and from what folks are saying, its pretty good secret sauce. Its fine, but its not “open source”–our only option is to listen and trust our ears.
