The fuse on the back of my 300DR appears to have blown and there isnt a spare fuse in the little “drawer” next to the power in socket (apparently there should be two in there). Is there somewhere I can buy these fuses if my retailer is closed please?
TomTom Audio is my go to dealer for the best stock of Naim parts
https (://) tomtomaudioshop (.com)
Do you happen to know if the 300DR uses 3.15Amp fuses or something different please?
It’s in the manual.
Its not just any old fuse. It needs to be of the exact, correct type.
Contact your Naim dealer - who (in my experience) could well post you some, ASAP.
Everything you should need to know should be stamped on the failed fuse. Measure its length too. Should be 20mm?
It’s a T fuse. If you’re in the uk then it’s a T3.15A you need from the Littel fuse co. Worth buying a few for any future needs.
I agree Tom Tom is good
I bought 2 for £3.47 including postage a while back
Strangely I couldnt find them in the Littelfuse co but found these on TomTomAudio website. Assume they are the right ones? They look the same
If Tom Tom are selling them as “for Naim” I would certainly hope/think so.
That is what I bought and has worked for years now
Thank you everyone. Bought a few from TomTomAudio so I have spares just in case.
