I have an iPad Pro 2018, which replaces the iPad Air 2. When I search « 10 audio.com » on the iPad Air 2, it finds the right site via google.
But via IPad Pro, I am directed to a pharmacy site, nothing common with 10 audio. Why?
Then another site: Positive feedback.com. On iPad Pro, i can’t put the site on my screen ( raccourci sur écran d’accueil). But can do that on iPad Air 2. Strange.
have you checked Settings/Safari/Search Engine setting, and perhaps compare all the settings here to your working iPad, going down to each sub level. Try using the “clear history and Website Data”. Also are you using the same Apple Id
Google search includes this top hit which looks correct:
but it redirects on clicking randomly to several pharmacy sites selling ‘uplifting’ products.
If you select the cached version however from Google it shows the correct site but either the hyperlink for the cached site info provided by Google or ‘orange link’ in the cached site go to a pharmacy site.
I had a problem a few months ago that the Guardian newspaper website kept resulting in my phone being sent to a site that tried to exhort bitcoins from me “to unlock your phone”. In fact deleting that page in the browser was enough to escape. But I couldn’t read the newspaper! It only did it when I was on WiFi and hence using Virgin Media’s DNS servers and it didn’t happen if I turned off the WiFi in the phone and connected via Vodafone 4G. My iPad wasn’t affected, because it was using the desktop site rather than the mobile site.
Ultimately I solved the issue by telling my phone to use Google DNS servers instead of Virgin Media’s. And then I started using the Guardian app which is better on a phone than the mobile version of the paper anyway.
So my suggestion would be to change the DNS settings in your iPad.
The issue here is that the website 10audio.com has been compromised by malicious scripts, sql injection maybe? It used to be a common problem with developers writing insecure scripts that were easily attacked.
Clearing the cache/power off etc won’t do anything as the problem is with insecure aplication allowing script injections on their server.
So some of its pages are being returned with links to the viagra (injected) whilst some go to the correct pages.
The site is running on an outdated version of Drupal 7.26 (should be V9) so very vulnerable to script hacks
Please contact the site owner and get them take action ASAP.
The apple dealer confirmed me that, it’s a site problem, not iPad settings.
I tried to reboot it, switch off and on, clear the cache before, tried different settings in Safari, went by google, google chrome and also Safari: still the same.
Anyone here use the IPad Pro 2018 or 2020? Can try to open “ 10 audio. com” site?
Nothing to do with DNS, but they are under network settings
@raym55 ste has been compromised via malicious scripting taking advantage of out dated software Drupal V 7.26 hopelessly out of date and vulnerable to SQL script injection.
Site owner needs to take down files from host server, update Drupal then re-install site files as attacker may have left a backdoor on the server.
Part 2 of your queery, I understand you want a bookmark on the desktop? so probably just a matter of visiting site, and tap the “+” icon to the left in the address bar.
Yes, I feel you are right. I responded you previously, when the iPad dealer responded. But I don’t understand how it can work on some iPad models and not other.
