Issue with NDX2
Hi Guys,
Need some advice. Today I powered up my NDX2 which is running an external 555 Power supply. However today the connection dropped out about 3 times as I thought it might be an Internet Glitch. However after it reset itself played music for about 30 minutes then just nothing.
No sound whatsoever. I thought was odd, so I reset my modem and Fibre Optic box and waited for a signal and still nothing. Obviously power is still running with the screen and lights on but no tunes. Has anyone else had this issue as I thinking a possible relay has failed in the NDX2.
Any help or knowledge would be greatly appreciated
Gavin
Australia
Any electrical pop sound at the speakers when it does it?
I’ve not had that on NDX2 However, if you say it accompanies a pop at the speaker, I had that on three faulty Naim Novas A few years back.
Might not be related, however. but the symptom of it playing fine and then going dead and then coming back on was the same
Check whether it has swapped output from or to RCA phonos or DIN. Electrical supply glitches can sometimes cause this.
Hi Richard,
Checked the Ndx2 Output and and the Din/RCA output as selected. However switched it into Din mode and still nothing however everything lights up as it should.
Hi Popeye,
No pops nothing. Dead quiet. Everything lights up as it should.
Try removing the 555PS, put the link plug back in on the NDX2 and connect this to the mains, just to rule out a possible issue with the 555PS or Burndy.
Doesn’t that usually stop audio from one channel only?
BTW, Good to see you back on the forum.
When you say that the music drops out, is that the only issue, or are there others?
Does the Naim app still find the NDX2?
If you log into your router, is the NDX2 listed as a connected device?
What music source were you using? Were you streaming from a local server or online?
I may be mis-rememberng, but I’m sure I’ve seen issues on this forum here where the din output goes, but RCA still works. So for that you’ll need a din-rca cable to test. If you have Prime, then you may get a £10 cheapie delivered for tomorrow for testing. Perhaps other can confirm if they have seen this before?
When you say everything lights up does a particular radio station show on the NDX2?
Specifically does radio station or selected album show on NDX2 screen?
Are u using Ethernet connection to streamer or WiFi?
What is preamp?
Profile says 272, but I found a recent thread where a 252 is now in use.
If any RCA pair cable is available, it can be used to test the RCA output of NDX2. This would require the NDX2 to be configured for RCA analogue output (easy), and the 252 to be configured for RCA on the input (bit more of a faff).
Hi James,
I did as you said and installed the NDX2 pug back in and removed the 555 Power supply out of the chain. Then I did a hard reset on the power button of the NDX2 and now I have no screen that lights up nor does the Naim Logo. The power button lights stays on and nothing else.
I have no power on the NDX2 now. Only the standby button show lit
That doesn’t sound too good. With the NDX2 powered off, I’d remove and re seat the link plug, just to check it’s inserted properly. If that doesn’t work then it looks like it’s time to call your dealer and get the NDX2 checked out.
David, I’m using a 252/Supercap.
Album art did show until I did a hard reset and now the screen shows nothing only a standby light.
Iam using Ethernet
I did install the NDX2 blanking plug and did a hard reset and lost the complete screen only now the standby button lights up and the network can’t find my NDX2.
I was streaming online with Ethernet no server.
I take it pressing the lit standby button on fascia (not remote) does nothing then?
When powered on does the screen light snd the NDX2 go through the “startup” display (graphic with a progress bar, whilst it initialises)?
After checking blanking plug, if button does nothing or screen is dead at startup then unfortunately it sounds like a hardware fault with NDX2 as @james_n said above :worried:
Yeah mate looks like it’s a actually failed now
