Issue with Preset list in App
Hello
I am using the New Classic NSC222 and have issues with the app since today.
The tunes that are in the Preset section of the application are no more selectable. I still see them in the preset list, however there is an “!” mark, and if i click them, they do not play.
I tried remove music tracks from the Preset then add them again, however this does not solve.
I upgraded to the latest releases of the app on my ios device (iPhone 13 or iPad M2, with latest iOS versions)
Also, the Preset items appear in the preset menu of the NSC222 however they do not play anything.
Any idea?
Thanks, Jean
Just to say I have the self same issue with my NDX2. I have logged out and in of Qobuz (my subscription had just renewed), reset and restarted iOS apps and the NDX2. It made no difference.
I have spoken to my dealer who was also puzzled by it. He will contact Naim Support. I have also emailed Naim Support.
Everything else, Qobuz included, seems to be working fine.
I have since found that pressing on the exclamation mark next to the preset in the app brings up a menu from which “Play” can be selected and works.
This obviously isn’t how it’s supposed to be but it is a little workaround.
Hello, thank you for sharing you face the same issue.
Yes clicking on the “!” opens a popup menu with the play option, which is indeed not as it should be, but at least we can workaround from the app.
However no way we can select/play favorites anymore from the streamers NSC222/NDX2 ! It appears this seems to be a BUG…
emails sent to both Qobuz and Naim support teams.
If you can also do the same, that could help investigating / solve the problem, thank you
Hi again
I got the answer from Naim Support, they have been incredibly fast in reproducing the problem at their side and identified the root cause (a change by Qobuz they need to reflect in our Streamer software). The fix will come but I have not release date.
Have a good evening
