Ittok 11lv to Linn Ekos SE
Continuing the discussion from Pmc upgrade prodigy to prophecy:
Or for that matter the Prophecy 7’s
For me, probably yes, but I’d want a Radikal2, Keel and Kandid at the same time. :zany_face:. And a big bank account!
Any views on the upgrade factor going from a linn ittok 2lv to a linn ekos se. I have a naim supernait and use dynavector hi output mc.
I think you are on safe ground with the upgrade factor as many feel with the Ekos 2. As the SE is still Linns current top of the range arm you should easily be able to get a dem. For me it’s more about whether the uplift is worth the expense which only you can decide. I personally would want a Keel and Linn cartridge to max it out. I see you already have Radikal2 so if your aim is to eventually go Klimax then Its just the next step.
I felt I had a better improvement getting the Lingo 4 rather than upgrading the arm from Ittok.
Mind you, I did also upgrade the bearing at the same time.
Many thanks for the replies so far. It is a second hand arm that is tempting me. I have the karousel and a tangerine k u v sub. I don’t think I would want to go down the road of really expensive linn cartridges. I also am low in space for a turntable preamp, hence the dynavector. Not sure if that means that the ekos se would be a bit of a false economy as it needs a better cart etc?
I upgraded my Ittok LVII to the Ekos 1 when it came out, and it remains one of the biggest upgrades I’ve made. I have an Ekos SE/0 now, and am happy with it. I didn’t do a direct comparison with the Ekos 1 - I auditioned Keel and SE as a package - but I’m satisfied that it was a worthwhile step up.
As others have said, there may be other options that are better value, however you already have the Karousel and a Radikal 2, and I assume you’re happy with the Tangerine subchassis. Leaving aside the very latest Radikal variants, the arm is the next element in the hierarchy.
I wouldn’t worry about the cartridge. An Ekos SE with a decent moving magnet will sound better than an Ittok LVII with even a high end moving coil. In your position, I would go for the SE.
In the early nineties when the Ekos was launched, I worked briefly in hi-fi retail. On a dealer visit to Linn, a free Ekos was offered to anyone who could bend a piece of Ekos arm tubing over their knee. None of us took up the challenge. I doubt if I was the only one to sell a few on the back of it!
A length of Ittok arm tubing wasn’t offered up.
That story is fab - many thanks
Where was Uri Gelder when you needed him?
I had an Akito 1 (heavily modded and upgraded) and then went to Ekos 2 which was superb.
The Ekos SE/1 I have now has been completely rebuilt by Linn. I purchased it used and started having problems with it. The bearings had gone and eveything that is serviceable was pretty much replaced.
I was very surprised by the extent of the problems. Since then it has been alot better.
It’s a great tonearm. The Ekos 2, I only had for 6 to 9 months but was perfect and trouble free. I used it with a Dynavector cart and it was wonderful!
Whatever you buy just be careful as tonearms are very expensive to fix.
That’s good to hear Dan. It is being sold by my dealer, so should be ok. Also depends on trade in factor of the ittok
