Ittok 3 to Ekos 1
Hi all. I’ve had my Ittok 3 for less than a year and very happy with it. An Ekos 1 has popped up for sale and is in pretty good condition from the original owner who bought it in 1995. Not sure if this would be a sideways move or an upgrade? My Kore/Karousel/Lingo 4 components are now in stock and I’ll be upgrading my turntable next month and it would make sense to do the tonearm switch at the same time if I go that route. Would appreciate thoughts from those with more experience and knowledge than me
The Ekos 1 (still using mine) is a significant improvement on the Ittok imo - injects far more energy into the music for one thing and the reason (along with ease of use) I chose it over the Aro. Had mine for 35 or so years and still sounding good BUT I did have it serviced by Linn 10 or so years ago. Amongst other things, if the stylus pressure knob hasn’t been used for some time it can seize up. But an Ekos 1 in great nick will beat an Ittok in my experience.
I’ve just had my LP12 revamped with a new plinth, tramp, lid and Krystal. I thought long and hard about changing the Ittok LVII for an Ekos2 or Arko at the same time and in the end decided against it. I feel the Ittok is more than good enough with what I’ve just added with the existing Kore, Karousel and Lingo4.
I recommend a Linn-repairable Ekos 2 with a nice deck like that - check serial with Linn but it’s quite high. A bit risky otherwise. My Ekos 2 bearings went last year and I’d always been careful with it and used a reputable dealer to work on the deck. Sounded really sweet after Linn fixed it though.
LVIII is a lovely arm but never directly compared mine to the Ekos. A few people feel the Ittok is more fun.
‘95 would be an Ekos 2 btw and I think it’s around 2000 onwards that Linn will repair.
I would suggest you send your Ittok to Paul Bird of Hi-Fi Gallery in Stirling to be modernised. He has been trained by John Nilsen (J7/Audio Origami).
P.s. Johnny (J7) does not service Ittok arms any more. But Paul Bird does.
I upgraded my Ittok LVII to an Ekos 1 when it came out, and it’s one of the bigger upgrades I’ve made in almost four decades.
I’ve never heard the LVIII, but many have said that it’s as good as or better than an Ekos 1.
Assuming an audition isn’t feasible, I’d try to track down some more opinions from people who have heard both.
Thanks all. I’m going to keep my ittok 3
Go for a Ekos 2 instead a major upgrade over Ittok and Ekos 1.
FWIW, agree with others here, thinking the Ittok is actually quite a good tonearm. Yes, there are maybe better subsequent Linn tonearms, Ekos 1, Ekos 2, Ekos SE… But there is something quite special about a well maintained good condition Ittok
Would agree with @Piccadilly above. If you decide to keep your Ittok, it’s maybe worth considering a bit of TLC, which might return a little sparkle to the sound and bring yours back to full specification, ready for another 30+ years of service. Can thoroughly vouch for this idea, having done something similar a few years back.
Just for fun, here a few nice photos of ours at home, and with a Troika.
@KenRose … Just curious, which version of the Ittok LV III do you have ?
From what I understand the later version III ( 2) is very similar spec’ to the following Ekos 1.
@Corry also suggests same idea.
[ edit : just checked your “systems pics” and it looks like a III (2). If that’s correct, you’ve got a real gem over there. Nice. ]
Good luck
Found some history on the Ittok - reproduced below - for anyone interested.
The Linn Ittok tonearm was designed by Mr. Ito for Linn, built in Japan (initially by Denon Parts Company), and launched in 1979 as the Ittok LVII to challenge the lightweight, S-shaped arm norm by introducing a high-rigidity straight arm design.
Linn Ittok LVII (1979–1989)
Launch & Philosophy:
Introduced in 1979 at £230, it prioritized maximum mechanical rigidity, a large-bore alloy armtube, and a perforated magnesium headshell rather than low mass.
Mark 1 vs. Mark 2 (Unofficial Designations):
Early Mark 1 units (pre-serial number 3,000 / ~1980) featured a 20mm diameter pillar, a two-piece counterweight, and a 5mm set screw in the arm collar.
Mark 2 units (serial number 3,000 and above) upgraded to a 25mm diameter pillar for improved rigidity.
Bearing & Material Updates (1983):
At serial number 12,000, Linn introduced a material change to the internal bearing shafts.
Cartridge Accommodation (1986):
At serial number 23,000, in response to the launch of the Linn Troika moving-coil cartridge, Linn enlarged one of the lightening holes in the headshell to fit the Troika’s unusual third mounting screw.
Finish Variants:
Also appeared periodically in a black finish designated as the Ittok LVII B
Transition to Linn Ittok LVIII (1989)
Rebranding & Adhesive Mod (January 1989): Renamed the Ittok LVIII starting at serial number 31,300. The mechanical 3-screw headshell clamping mechanism was replaced with a specialized aircraft-grade adhesive.
Linn Ittok LVIII/2 (1991–1993)
Final Evolution:
Introduced in 1991 (resetting the serial number sequence to 0001).
Design Changes:
It adopted the integral armrest layout from Linn’s flagship in-house Ekos tonearm (meaning it no longer required a separate arm-rest hole cut into the turntable armboard), alongside a strengthened headshell.
Discontinuation:
Production of the Ittok ceased in September 1993, by which point internal performance had closed in on the higher-tier Ekos line
Hope that’s all interested to read and learn about the venerable Ittok.
Which ever direction you choose, good luck :+1:
BW
R
Wise decision, I asked the same question of my dealer for years when in the same situation as you ,kept getting same reply . Bypass Ekos 1.
I’ve had a really C**p Epos 1, wonder how it could go that wrong.
Ittok anyday.
yes I’m keeping my Ittok 3. I’m very happy with it and if I ever change arms it will be for a bigger step up
Good thinking. My thoughts on the future of my LP12 have crystallised around “It’s Akurate spec now, no more upgrades as the Ittok is more than up to the job at this level. If I win the lottery or inherit a large amount of cash, I’ll consider Klimax, big bang, if I like the way it sounds.”. :blush:
Here’s a pic of mine, why would I change it :man_shrugging:
Super photo of your LP12 and Ittok
And new Krystal too :+1:
I did this upgrade years ago…it is a clearly audible improvement. I would have it checked over by a specialist. You can check the lateral bearings with the pendulum swing test.
What a lovely plinth you have there.
Really nice.
Thanks, I’m really pleased with it. Just had it fitted and asked my dealer if he could order one from Linn with a really nice grain? He said there wasn’t really a choice so we’d have to see what turned up. When I went to pick it up he said “Well I think you’ve done really well with this one” he wasn’t wrong. :blush:
@ratrat
Gorgeous pictures and wonderfully helpful post. The fluted walnut plinth is stunning and your Ittok is in terrific condition. The Troika looks so right with it doesn’t it?
@Paul52135
She looks a real beauty highlighting the beautiful wood grain.
You just can’t go wrong with walnut!!
Adding to the love of an LV11 with a Troika. :heart:
That’s brilliant
Maybe I’m biased. But honestly think the Troika is one of the most attractive industrial designs around, certainty best looking or most attractive cartridge.
Curvaceous and colourful.
BW
R
