Hi Atyn,
what power amps are you going to be using?
NAP200 and below you may require ‘special active leads’ made to order from Naim - NAP250 & upwards not a requirement. Perhaps @Richard.Dane may wish to comment further.
I found the active leads less of a requirement on the ixo than on the hicap / snaxo. It could be that I’m misjudging though since the ibls and sbls I tried it on are not on the same level as my Ovators.
I am using Din to RCA cables and horizontal biamping.
Linn Lk100 or Quad306 (I’ll compare them) for the bass/mid and my Krell KSA50 clone derated to 15watts for the treble.
I’m building a passive preamp currently, using a motorised ALPS pot and Glassware Audio’s Akido tube buffer mainly to provide a low output impedance to drive both amps.
