Sorry you did not win: looking at the Judging Criteria I thought you had a strong entry.
Years ago I used an R6 for slide film, mostly with a 21mm, never had a 50mm, and some with a 180mm. The move to digital was equally minimal, but just with a DX 16-80mm zoom (24mm in 35mm film terms at the wide end to 120mm), all second hand too, as indeed was the leica. Finally overcome the sentimentality and selling the old stuff as now a few years into retirement it is time to reasses, so maybe a Q is possible…
Could sell the Naim system, reduce the box count, use a Bantam One instead…
Kind regards
Chris
