Join multiroom using the Naim Remote Control for a Nova
Hi! I have a Qube and a Nova, and I just figured out how to join a multiroom using the touch-buttons from the Qube. Love it, that it’s easy without using the app. However, if I start on the Qube, and want to join the multiroom from the Nova, I’m struggling to find how I can do that using the remove control that comes with the Nova. There is a button for it, and can see what to join on the Nova screen but nothing happens if I select the Qube/Multiroom to join.
Should it work, aka a bug? Or do you experience the same, or know how to join from the Nova remote control ?
Pretty sure you can’t do it with the remote control as I think that is for outbound only multiroom. But you can do it from the app. I am assuming a Qb1; I don’t know if the Qb2 is different.
I’ve just tried and it doesn’t work. If I start on the Qb and then select the Qb via the remote on the Atom the Qb switches to multiroom and goes quiet. So it’s clearly the case that the multiroom on the Atom is outgoing, as PW42 suggested above.
Same thing here.
But it’s weird that I can opt in from the Qube 2, but not from the Nova :confused:
