Just Got NACA5..Gosh!
I was using some cheap Van Damme black speaker cable but just purchased some brand new NACA5 cable, 3.5m, that arrived earlier today
Can’t quite believe the difference NACA5 has made to the sound
Hope I’m not imagining it :grin:
Congratulations to a fantastic Speaker cable ! :sparkles:
Is it true that NACA5 needs running in?
Yes it’s going to be even better :drum::victory_hand:
It can take a while with NACA5 but there’s definitely a point after some months of use where it makes remarkable gains spacially with depth in particular coming good. Quite why it might be so, I really don’t know, but I had the same thing happen with two sets of NACA5 (one 7m per channel, the other 10m per channel).
Best buy used then!
But be prepared to cut off the ends and re-do the soldering onto some nice new SA8 plugs. That way you can be sure…
I had the dealer terminate with Naim plugs & Chord Ohmic banana plugs. They’ve done a great job of soldering, very neat
These are crimp plugs.
ChordOhmic ChorAlloy™ plated 4mm and spade loudspeaker connectors are designed to bring electrical and sonic benefits to speaker cables everywhere. Optimum contact via Hex-gun crimp termination.
Actually I didn’t check the speaker ends, just the Naim plugs and they were perfect so I’m trusting that they did the correct thing on the Ohmic‘s
I’m just leaving the hifi playing as much as possible to run in the NACA5 a bit
Sounding excellent already. I particularly notice the difference in vocals as I’m able to follow the words much easier than with my previous cable, has anyone else noticed this?
Of course it could be my imagination :laughing:
NACA5 is a rather good choice of cable. Enjoy it. As Richard says it can take a bit of run-in but its an upward progression.
Originally posted as a spoof review on Amazon for some Audioquest speaker cable, I thought this might amuse you as a satire on the whole speaker cable thing:
1.0 out of 5 stars
Reviewed in the United States on November 15, 2010
We live underground. We speak with our hands. We wear the earplugs all our lives.
PLEASE! You must listen! We cannot maintain the link for long… I will type as fast as I can.
DO NOT USE THE CABLES!
We were fools, fools to develop such a thing! Sound was never meant to be this clear, this pure, this… accurate. For a few short days, we marvelled. Then the… whispers… began.
Were they Aramaic? Hyperborean? Some even more ancient tongue, first spoken by elder races under the red light of dying suns far from here? We do not know, but somehow, slowly… we began to UNDERSTAND.
No, no, please! I don’t want to remember! YOU WILL NOT MAKE ME REMEMBER! I saw brave men claw their own eyes out… oh, god, the screaming… the mobs of feral children feasting on corpses, the shadows MOVING, the fires burning in the air! The CHANTING!
WHY CAN’T I FORGET THE WORDS???
Do not use the cables!
8,955 people found this helpful
Customers who viewed this item also viewed:
* 45 dollar a gallon milk
* uranium ore
* a 2700 dollar HDMI cable
* even more absurdly price AQ cable
* “Touched, The Jerry Sandusky Story”
* a horse head mask
* a rubber scrotum so one can teach testicle self exam
* a 40,000 dollar relaxation capsule
* fresh, whole rabbit
* a plasma cutter
* $500 pdf download of a paper entitled “The 2009-2014 Outlook for Wood Toilet Seats in Greater China”
Mark (who also uses NACA5 and thinks it’s good!)
:rofl: :rofl: :rofl:
Can’t go wrong with NAC A5, even if you go on an exotica cable journey you find they’ll just get the job done in any Naim system.
Glad to hear the dealer has taken care of termination nicely also.
Next stop, Super Lumina :wink:
I have VDH cables in both my Naim systems and home tried NACA5 and Lumina. Recomended by the Naim dealer. Perfect sinergy with Naim / Dynaudio setups.
No you’re not. NACA5 is a fantastic performance cable and great value. Most naim products were voiced using it.
That is no imagination! That is exactly what the naim cables do. Thought the same - easy to follow on lyrics. Very good with naca5 even better with SL. Enjoy the cable - I had it in main system for 35 years. Have 3 or 4 sets of naca 5 :sweat_smile:
35 years? That means you must be like 98 years old now? I will have changed cables 3 963 900 times in 35 years. Persistence!
Got a headache today - don’t understand your calculation :joy:
