Just installed an ex-demo 555ps to my NDX2 last week. Go for the 555, you will not regret it.
I agree the NDX2 with 555PSDR is sublime.
@IvdZ sums up the difference well between NDX2 XPSDR to 555PSDR on another thread.
Doesn’t matter, the 555ps in a different league and as I say, if you ok with an ex demo unit not that far from new XPS money
Ex-demo 555PSDR in year 2014… is it a good idea to get it still?
It is better, I agree, but when paired with an NDS like mine, the 555 uses two Burndies, or all the 555 has to offer. If I had an NDX2 with a 555, I would be thinking about the ND555, which I definitely can not afford.
You can think about a second 555 instead!
You cannot afford yet, but you may in a few years time when they come about used!
I’ve also ordered a new NDX2 with XPS-DR together with SN3 Hi Cap and Evoke 50 to replace Nova and Special 40s.
Pleased with the old set up and although I said I wouldn’t go to racks of gear again the sound bug bit.
Unfortunately I heard a similar set up at Audio East last year and the sound niggled me thereafter.
Thought that was the best room last year at Audio show east John, trounced the bigger systems imo. Funny how it ticks away in our brains👍
I agree Gaza but it’s cost me. I’ve since heard the big Dynaudio speakers and they were very good.
At more reasonable cost I’ve gone for the Evoke 50 as I prefer the Dynaudio sound to that of Focal.
I know…it started for me with Muso…then Nova…then other bits, but fun and enjoyable.
tell me about it!!
John maybe you could keep the S40’s? They will probably come alive with the new kit and then live with it for a while and upgrade if you still feel the need - just a thought
Hollow, I’m very pleased with the Special 40s and think they are a brilliant speaker.
Having heard the 50s they have more depth, as good a mid range and a better treble. I think Dynaudio are hard to beat for value at the moment.
As I’m getting on a bit I thought I’d better change now before it’s too late.
Well…
I had a NDX2 at home, for a couple of weeks, and didn´t find any major improvement from my old CDX2 (NDX2 playing the ripped CD´s from a NAS).
So I kept my CDX2 and began using my Hiqute2 as a TIDAL streamer, as I´m basically listen my CDs.
My system: Hiqute2 - CDX2 - 282 w/HicapDR - NAP300DR - Dynaudio Contour S3.4 w/ VDH cable
What is a Hiqute2, I just googled it, and nothing came up?
Unitiqute2? hardly a match for a NDX2 I’d expect…
Of course NDX2 it´s a lot better but my point was if your main source of music is the CD´s you have, CDX2 is very good also, and you can enjoy TIDAL/FM/Internet Radio w/ a Unitiqute2. Not so bad I tell you.
But one Burndy from a 555ps does more than one from an xps.
No different to those with either an NDS of ND555 using 2x 555ps and utilising only the one half of both!
