Keeping SBL's Running
After by Brief spell with a pair of IBL’s i’m heading back to by roots with SBL’s (I just know where I am with them) Clearly Naim no longer supply anything or Service SBL’s and Darren at Class A won’t service the Passive Crossovers. So how are SBL owners keeping their speakers going… what’s the best options for tweeters, Crossover Servicing, and dare I say even Bass/Mid Drivers (yes I know buying a pair of Credo’s for their Drivers may be an option)
Given I know plenty people are still hanging their trusty SBL’s on the end of ‘End Game’ Electronics if feels wrong piecing bits together for them like we’re trying to keep an old Ford Cortina running !
Are there specialist companies out there totally refurbing SBL’s these days for enthusiasts ? I’ve toyed with getting some SL2’s again but to be fair they are getting on a bit and to be totally honest i’ve preferred SBL’s to SL2’s in a few systems i’ve owned and heard (although I accept SL2’s are a superior design, perhaps i’ve never had them set up optimally)
I’d love to hear how people are getting on with SBL’s nowadays, how they feel they compare to more modern ‘equivalents’ such as Kudos S20a and why they’ve never moved on from a £500 pair of speakers with perhaps £40k of Black boxes in front of them…. some system pics would enhance the thread too !
Best
Mark
I’ve never owned a pair of SBL’s. I jumped from Isobariks to DBL’s and bypassed them. However, my son has just acquired a lovely pair of SBL’s circa 1988 with the MK 2 drive units. I’ll let you know what he learns.
This learns us that at least one kid on this planet was raised properly.
He normally builds stuff like this…
…so SBL’s should be easy to master?
For both the gaskets are very important!
After a couple of decades they’re still running strong. Not an issue to report but i think they’ll soon have crossovers refreshment…..
Clever!
So you’re zippin’ up your boots then.
I also prefer the SBL’s, now at the end of a 500 system, to SL2’S. I ‘ve owned the latter prior to S600.
What’s the BHP on SBLs?
Has anybody tried the bass unit from a mordaunt speaker, modified i no but worth a try if all else fails
Does anyone know where I can get a new set up pack including gaskets?
At one point, TomTom Audio in St Albans UK did gaskets (mid to bottom box) and the foam grilles. I don’t know if they still do or will.
Elsewhere on this forum somebody recently re-did the foam inside the middle box.
Others have replaced the tweeters with the nearest thing to the scanspeak originals.
When it comes to passive crossovers, I would speak to John Jackson at JJS Thatcham, a former naim engineer and approximate contemporary of the SBL.
to the best of my knowledge this will make up a decent seal kit for SBL’s to more or less original spec, a little bit of trimming / cutting needed but it’ll do the job
Thx. But what do I do for the gaskets?
He has shown it above, its just closed cell foam. I am sure there is wonderful stories circulating on how special the foam is. But its just foam. Get some thats of sufficient width and use a Stanley knife to cut yourself out a new gasket.
Personally I just use clear silicone, I use Dow 781 as its a tadge firmer than cheaper options which is handy when squirting it out. It works perfectly well in this context and again, stories will not doubt circulate on how naims suppled loctite is better for some reason. I would rather bet its just what was available in smallish sized tubes to naim at the time.
There is also self adhesive .5mm aluminium ‘labels’ on amazon which are great for the spikes if yours are knackered.
Finally check careful the crossovers where the amp connects, are those sockets good and firm? This is a frequent failure point on sbls because of naca5s accursed tension, you may find the solder needs to be reflowed to remake the join.
Sorry, but what do you mean by crossovers?
Just talking about general upkeep of old SBLs the black boxes on the back of the speakers. If you don’t have any chances are you are running active and this does not effect you.
Have to say the opposite for me. I owned them simultaneously and used them active and passive in both my systems at various times. I think the SL2s may lack a shade of the lightning speed and immediacy of the SBLs but make up for it with a richer, more natural just classier sound. Easy win for me.
Incidentally I used the SL2 crossover on my SBLs when they were run passively. It was better than the original. Newer or better spec?
Both are fussy on setup especially positioning and require careful installation. I think the SBLs might be more forgiving of lesser source and amp.
Both fine speakers. No idea how I would ever replace the SL2s.
Bruce
I bought my SBLs new in 1997 and they are still sounding fantastic! I now work in the industry and have been fortunate to hear loads of speakers up to £75K a pair. I have other speakers but I’m always relieved to come home to my SBLs. I run them on the end of a top spec LP12 and ND555/2x555DR with a 552 and 350s.
I have used them in 7 houses and they have always coped remarkably well with very different and sometimes difficult rooms. Each time I dismantled and reassembled using Naim gasket kits and good Dow silicone, where the Naim tube had gone hard. I always kept a few kits in stock due to our frequent moves!
They had new grilles from TomTom in StAlbans about 8 years ago and new crossovers about 15 years ago. I regularly torque the drive units to the correct figures and make sure they are spiked rigidly to timber floors or with Naim Fraim Chips if solid floors.
SBLs love having solid walls behind them and respond to careful setup - as all speakers do - but they certainly run rings around the majority of modern speakers. It’s rare to find another speaker that times as well - some Magico models, Russell K, and … well now I’m struggling! I keep trying other brands but for enjoying music of all types SBLs are still really hard to beat!
