Klicking Sounds
Has anybody else experienced clicking sounds that the supercap makes spontaneously or upon volume reduction?
Why do you think clicking sounds are coming from the Supercap? There is no active circuitry in the SC between the preamp output and poweramp. You might need to be more specific about the problem description and how you came to the SC conclusion.
