Knowing my Legacy NaimUniti2 firmware version
Hi All,
The display of my NaimUniti2 has faded since a long time, so I am not sure about the firmware version it has.
On the OS apps it displays the “Streamer Version” under Settings > Informations as 3.21.00 as per the screenshot (it is in french : Version du streamer).
Can I rely on the firmware version given by the OS apps ? So that I will be able to move on on the latest firmware update 4.9 once it is fully released for legacy devices vis USB-RS232 cable.
Thanks for your lights.
Yes, it should be correct and yes, you can update to 4.9. Note, you should also update the App.
