Kudos KS-1 and NAP 300DR
I know this has been covered before but a search doesn’t seem to be finding the answer readily for me.
Can Kudos KS 1 speaker cable be used safely with Naim original classic amplifiers mainly the app 300 DR ?
.sjb
I used it for quite a while with both 300DR and 500DR with no issues. I only replaced it when some used Super Lumina at a decent price turned up.
It’s only the really old naim Amp’s that can suffer from that, the 300dr will be fine
Yes indeed
Ask @Polarbear
He has a very top end system and enjoys KS-1 no problem
As do I on my Supernait 3 :+1:t2:
Used this combination for a couple of years, no problem.
Evening SJB,
Yes, perfectly safe. Kudos do a lot of work with Naim amps and many Naim users use Kudos speaker cable.
I have been happily using it for many years now.
Thanks everyone, just wanted to be sure.
.sjb
just to add, I also have KS-1 with 300DR into Kudos T505 superb cable
Yes, works well
Had two runs of KS-1 on my two NAP 250s.
DG…
I use it on my olive 250.
Have been using 300DR with KS1 and Kudos S20A for few years now. Match made in heaven. I hope Kudos will not blame me for sharing their advice: “We have found that the KS-1 cable doesn’t really upset the Naim amplifiers but if you want to be extra safe I would suggest a minimum of 3 Meters”. My enquiry was about the adequate length of the cable… I generaly listen to good advice and my length is 3.5m. KS1 is a breeze to shape.
I’ve used KS-1 with 300, 500 and 500DR. All worked beautifully.
In fact Cymbiosis, who supplied and terminated my KS-1, contacted Naim to confirm the length was okay. Fantastic service.
