I know there are a few T606 owners on here. I’m interested in what you’re using with them ?
ND555/555ps/252/Supercap dr/300dr/S/L loom music from Core or Qobuz.
ND555/2x555DR/552/500 - but I suspect the 300 would be the right match. The Kudos Super 20s I had previously changed drastically going up the chain 200/250/300/500 which I did over many years - but these don’t seem to be that impacted by going up from the 250 to the 500. Strange.
I figure it’s because the Treble isn’t as hot as with the previous generation - and doesn’t need the 500 to tame it.
Devialet 220 Pro and 72/140
CDS3/555DR/552DR/300DR/Hiline, Powerlines All Round/MusicWorksG3 Sparkly bottom and Kudos Loudspeaker Cable/Full Fraim.
Linn KDSM/Klimax LP12, 552Dr/500Dr, Chord Music, Fraim/Sonority.
Used to have a 300Dr and that was great but the 500 adds a certain gravitas.
CDX2+XPSDR+282 (252 is arriving)+SCDR+250DR
Thanks all - that’s much appreciated
James
NDX2 & 555ps
252/250DR
LP12
Folks - thanks again. I’ve long been an admirer of the Titans and the 606 looks ideal from a size perspective, having a similar footprint (height and depth), albeit narrower than my Shahinians, so they get the lounge acceptance blessing (as well as looking rather handsome too)…
I was curious as to the amplification you guys are using as that sets the minimum that I’d need if I returned fully to Naim. My present Devialet setup allows an easy upgrade to active operation, with only one other box needed which is an attractive option.
Time to see if I can borrow a pair…
I recall speaking to Derek about using Devialet and he was pretty enthusiastic so you shouldn’t have any issues.
Anyway, great speakers - just so easy to listen to.
Cheers Dave - I remember well the thread on your Titan journey
Linn LP12
Naim 282, SuperCap, SNAXO242, FlatCap XS, 2x250DR, NAC A5
LP12 (Radikal, Keel, Urika, Ekos SE, Krystal), Uniti Core, 272, 555PSDR, 300DR, Kudos Titan 606, Fraim, Morgana Interconnects, SL Speaker Cable
Hmmm, a bit bigger all round, I think! To my eyes the Titans don’t blend into a domestic room quite as easily as Shahinians. Perhaps it’s those black front panels. Both great speakers though.
They’re pretty damn good and I’m running mine passive. Plus look great
Taking delivery of 555psdr to replace my xpsdr.
With Kudos Titan T88s
What are your thoughts on what I can look forward to?
Did the 555ps take long to come on song?
I know what you mean Chris. I should have said similar footprint. Depth is approx the same and 606 is slightly taller. Only one way to really find out
I run NDX/XPSDR/SN2/HCDR into mine, bought to replace my C20s which I had 8 years. Price was too good not to snap them up.
Currently looking for a 250 then a 282 in the future but happy with current sound from the SN2.
