I use a separate network with an own managed switch for my Hifi stuff. My switch is a Netgear GS108T. It is connected directly with the router. All LAN cables are CAT 5e or higher. Following components are connected with the switch: UnitiServe, Naim NDX 2, Oppo 203, Amazon FireStick 4K, Apple TV, Technisat cable receiver.
The UnitiServe is connected with 1 GBit. The NDX 2 is only connected with 100 MBit? Is this a limitation of the NDX 2? The cables of the UnitiServe and the NDX 2 are the same.
The connection speeds of the other components are not the same. The Firestick, the receiver and Apple TV are on 100 MBit. The Oppo is on 1 GBit.
I have tried to change the used ports of the components. No effect on the speed. Do you have any ideas, why the connection speed are different and not always 1 GBit?
Short answer for the NDX 2, long question. Thank you very much!
Does anyone have experience with the Amazon Fire TV Stick 4K? Or is this question off-topic in this forum?
As Chris says the Naim streamers use Fast Ethernet as opposed to Gigabit Ethernet. There is probably a tiny SQ advantage in using Fast Ethernet as well as less conductors are used for the duplex connection… ie 4 are used as opposed to 8.
No experience with the Amazon fire stick I am afraid. I use Smart TV, X Box and AppleTV for my 4K web streaming. The best rendition comes from the X Box… However if you are using 4K at 12 bits per colour, you need to ensure you are using a higher bandwidth HDMI lead than the default inferior 8 bits per colour.
